General  Leaking
General  Leaking
Aylesbury, Bucks,
It was noted that the gear box was leaking oil, so much oil we had to top it up every two weeks. Finally the clutch has given up so it needs to be fixed. Quoted £1700 which I thought was too high, so it's now on the drive being taken apart
Modifications
Leaks lots of oil
If it's the same as the 169 1.1/1.2 gearbox
The original bearing is specialised, read expensive
6204AG15J30 I found some new old stock
It a glass reinforced plastic cage, there is a reinforcing ring on one side
@rmjbn1 successfully used a standard metal cage bearing SKF Explorer 6204 C3
Five years, 25k miles later and it's still quiet so apparently holding itself together
Although I'm intrigued that later Puntos with the same C514 gearbox got upgraded roller bearings?
A recognised weak point?
Presumably these would be fine to use in a Panda?
I've got into the habit of checking gearbox oil level a couple of times a year
And I would also replace the driveshaft seals whilst the 'box is off the car. Much easier than in situ :/
What it the name of the tool that is needed to get the clutch off. It's got 6 side but it's not a standard spline bit but close.
It won't me attach a photo but I'm working on it​
Clutch now removed. I found a Torx that had enough grip, even if it was not perfect. A lot of oil behind fly wheel. Suspect i might have second oil leak from engine.
The original plan was clutch and the three shaft seals plus drive shaft bearing. But it now depends on what damage I find inside.
Fingers crossed. If the input shaft bearings break up they can do some damage
Yes, my clutch was being lubricated from both sides, input shaft seal and also crankshaft main rear seal had failed on mine around 100k miles
As long as all the gears work without dropping out or whine
They are normally fixable just with seals and bearing
A little ratting, especially in neutral is okay and is normally the first sign of an input bearing fault
Here the original thread, from person that first posted it
The bearing is the wrong type, it shouldn't be sealed, it has it's own oil feed
Also the bearing shouldn't be jammed all the way down to the gear, there's a little gap, measure it first, tap it down to some feelers guages or similar
There was a common problem with oil leaking through the flywheel bolt, the fix is to remove the bolt and apply some sealant, can't post the service bulletin as fiat site is down at present, I assume Fiat will have fixed this on latter cars
Fiat identify special bolts by the fastener type
Ribe on fiat are normally in high stress areas
Door strap, cylinder head
It's so the wrong bolt can not be accidentally fitted at manufacturing,.I suspect
The clutch bolts even though they aren't tightened very tight are normally grade 12.9
They are supposed to be replaced, I suspect it because they come loaded with thread lock
I clean and reuse with one drop of thread lock added, as do most grages, as they aren't cheap
Gearbox is now in bits. It took 3 hours to gently get it apart making sure I did not damage anything. I expected to find some metal in it, but it looks like the bearing cage has totally gone and is now just metal fillings! At first I was worried when two ball bearings fell out of the case, not knowing where they came from. But turns out that is what is left of the bearing. I guess there must be more ball bearings but ran out of time and not found them yet. On Tuesday I plan to check all the parts for damage.
  • drive.mp4
    2.2 MB
Your looking for 7 ball bearings, there hardened so will do damage, so it's important to find them all
They can make there way into the diff housing
There is a magnet inside the box to.catch metal can't remember where about
The cage is plastic so isn't important
