Hi there,
Perfect timing for the winter: the internal heater blower has decided to stop working!
Mega annoying because I can't heat up the car, and more importantly I can't properly defrost the windscreen. Just keeps freezing from the inside.
This happened a few weeks ago but it started working again randomly, but I can't hop around it this time because of winter!
I've checked the fuse, that's fine. Taken the 2-wire and 5-wire (I think) connectors in and out of their sockets under the passenger footwell. Did get slight activity once I did this then turned on the ignition, but died after.
Jiggled the 5-wire around a bit whilst it was plugged in and ignition was on, again, slight activity but none after that again.
Also worth noting this happens on heater settings 1-4, so even when it bypasses the resistor (setting 4).
Any guesses to what the problem is, and more importantly, how much this might be to get fixed?
'56 GP 1.2 Active if it's any help!
