- Joined
- Apr 8, 2008
- Messages
- 16,742
- Points
- 3,186
Wow.... a load of **** that is....
I just assumed you would pop em down and pull the D bushing out and slot it and off you go....
Oh no....
They are 3 pieces, the u clamp - bushing and top plate....
The top plate and u clamp are pressed together...
You cant seperate them without either cutting the pressed ring or grinding it....
Once it seperates you cant press it back together either....
Ended up using longer bolts to allow me to pull it all back into place.... whcih is a bitch to say the least...
Never again.... ill happily replace an outer... but never a middle again
Which i hadnt touched it now....
Ziggy
Oh no....
Ziggy
