Technical injection system failure
pinemartin
Been some time since I been on the forums. I have an 07 Panda Acive 144000 miles on the clock. Driving from Cambridge to Bedford .Motorway and town driving. No loss of performance just this amber light which I found to be Injection system failure. Any thoughts ? I will obviously get it sorted asap. Could it be fuel contamination ? Faulty sensor ?
From other posts it does seem to be generic, meaning it could be almost anything. Most other posts report some issue such as loss of power . My Panda was rolling along as normal. Hopefully I will find out soon enough. Thanks anyway, will keep you posted.
Unfortunately no code, no symptoms, no real direction to go
I started a thread cheap scanner known to work
It’s only been up a few hours though
Stared up following morning and it was clear. It still is. A computer glitch ? who knows ? I'm old enough to remember a dashboard occupied by an oil light and ignition light, not much else. Dash lights up like Blackpool illuminations and it's a relatively old car.
Does your scanner work on all makes ?
Scanners should work on all Panda engines
OBD a standardisation of OnBoard Diagnostics
Developed for Californian emissions by Volkswagen in the 80's
Once all cars went Fuel Injected and Catalysed @1994 it was on most European cars
OBD2 Was with us by 2004 and offered far better coverage.
Limitations ... Engine codes only for cheap scanners.. no ABS etc
A lot of 'detail' is for modern kit.. turbos DPF
and often VW.. or Japanese biased
But.. every code a 169 pandas motor is going to generate will give an accurate P#### fault code
Searching that Code on here will find your likely Panda Prognosis AND FIAT's take on the Codes I/D
There's some much electronics in cars that the only way you're really going to know what is going on is with an OBD tool, otherwise you're just p!$$ing in the in the wind.
