- Joined
- Sep 14, 2009
- Messages
- 19,962
- Points
- 3,972
I have read everything I can find on the subject including the totally useless Spanish pdf file that gives absolutely nothing helpful for left hand drive never mind right hand drive.
Has anyone done this job without removing the pedals box.
I have taken out the driver's seat for easier access (lie on floor with feet on back seat). The resistor is right up against the firewall above the pedal box. The resistor pack can be seen by moving the air recirc damper and looking up inside. But access to remove the resistor looks impossible without removing the whole pedal assembly.
Has anyone done this without removing the pedals as a complete assembly? If so how is the pedal box / assembly removed?
Someone says he disconnected the steering column and pushed the clutch pedal down, but I cannot see how this would make any difference.
I could imagine that completely removing the steering column might gain access but folks will understand I dont want that job if its not necessary.
HELP!!!
HELP!!!
