Oh god, I found good stuff to read right now(by discovering this topic)
Enjoy your night then
What modded chip image do you talk about? If you bought something that said modded, compared to the original and there are no differences, well then, you got ripped offHave seen this before.
What do you mean by reaching something (what?) with 18F ECU?
Re BIN files, did you at least read the first point in this thread?
Actually, I did. Your knowledge is awesome, but did anybody tried to upload modded data into 27C512 and work? those files that you put to download, they are default, right? They are not the modded one.
I am searching for BIN file that is modded by autodelta, novitec, etc. That I can test as many as possible on rolling road and choose the best one (from results)
Yes, they are stock images from the mentioned cars. Re uploading, yes, many people did, there is a couple of folks in PL that mod the chips on a per-car basis, but those are usally done for heavily modded engines (cam shafts, 4 throttle bodies, etc.), nobody cares to just chip up the stock engine for few HPs. Mine is reprogrammed to run turbo and works a charm as well. There is a guy around here (McRitch was it?) that sells properly modded chips for 1.1 SPI Cinqs. Look in the guides section, you will find his guide there.
I would like to see these "big tuners" modded chips too, just out of curiosity.
I know that this is very old message, but I'l try to answer anyways...(...)
the problem was the injector pulse width is so low. so the injectors where outputting more of a spit of fuel then an actual stream. With this set-up even the 75 ejectors caused idle problems.
So the other day I thought... punto 75 was batch injection... if fiat could make it run smooth and pass emissions then so can I.
- it does not run on Windows (I will spare you the tech talk why, I tried, it just doesn't)
As far as I know the batch injection is the same as SPI, so once per engine cycle, and the injection pulses on idle are very short, which is a known problem for 4th generation LPG installations. Another proof is the fact that Punto 75 will start and run on IAW-16F ECU and vice versa - Punto 55/60 will start and run on IAW-8F ECU.
It will start and run, but of course not as well as on the original ECU.And it runs well? So on my Punto 75 I can put a 16F ecu (for example from a Cinquecento Sporting) with it's key (for immobilizer) and the car will run? It will run well or it just start and will not drive well?![]()
