Technical IAW ECU Live Mapping & Tech Info
which xdf are you working from.
you will understand that I spent hours and hours of testing and research to create around ten xdf according to the eproms that I was able to read in order to compare the different maps and that obviously I will not share all of that;
I am however here to help and guide your research so that you can have the necessary data to modify the essentials on your car.
The XDF I’m working from is the one you uploaded — I’ll re-attach it here so that we’re aligned on the same setup.
I totally believe you when you say you spent a huge amount of time building and comparing different XDFs; I’m just trying to learn how to approach this myself. I don’t really have a clear idea of how the searching process works inside a raw bin. Could you guide me?
For example, I was looking for either an ignition table or a fuel cut-off table, since I’d like to remove the cut-off and make some test runs. This ECU is just for testing, so I’d like to experiment with a few things.
Are there known patterns to follow when searching for maps in the hex? How do people usually locate tables like ignition advance or cut-off thresholds when there isn’t much documentation available online?
Thanks so much
  • Panda 900i IAW16F.zip
