Nope, I made one myselfIf you have figured out the map addresses making up the xdf file is a piece of cake
Yeah if i had it would be
Yeah if i had it would beAny way you would share your xdf ? I need to change WOT fuelling, fuel enrichment and rev limiter.
It is not my intention, not for quite a while at least. Reason being, I do not want to find tons of "mapped" chips on ebay the following day.
But if you are after these simple things, you can try getting your hands on something called ECM (a tuning program) that should have some basic maps pre-defined for this ECU, or at least 18F. Also I am not sure what do you mean by fuel enrichment here, coolant dependant?
Woj,
Im in need of some information that I hope you might have.
the punto 75 ecu runs batch injection as you mentioned.
do you happen to know when and how many times injection happens during each engine rotation.
or maybe you can tell me if the timing is the same as the spi. if so I will be able to find the information myself by painting the timing wheel and using a strobe connected to the injector.
Really funny you ask that, we just had a very extensive discussion about that on the PL forum with lots of speculations.
Bottom line is:
The batch-injection in 8F/18F ECU happens once per crankshaft rotation.
When exactly it is difficult to tell, but a well educated guess is at TDC. At least that's what the Punto manual says for the half-sequential 18FD ECU. Here (half sequential) I guess every pair goes on every crankshaft rotation, so all-in-all there are two injections per crank rotation. But this part is yet to be confirmed.
In the new MPI Seis and similar engines with full sequential injection I think it is clear...
The reason I ask is because ive had idle mixture problems with my car.
my injectors are about twice the size as standard (not really the problem)
I used to run 2 banks (back one is 1+4, bank two is 2+4)
each back fired twice per engine cycle (720degrees)
the problem was the injector pulse width is so low. so the injectors where outputting more of a spit of fuel then an actual stream. With this set-up even the 75 ejectors caused idle problems.
So the other day I thought... punto 75 was batch injection... if fiat could make it run smooth and pass emissions then so can I.
changed the settings to batch injection with 2 injections per engine cycle.
this also ran poor because the pulse width is the same.
so I changed it to one injection per cycle. pulse widths went from 1.1ms to 1.6ms engine idle instantly went smooth and afr went from a VERY jumpy 11 to 13 afr to a perfect and steady 14.7
I was going to mess with the injection timing to see if it can get even better.
Im guessing the standard cento ecu runs the same timing as the 75 because people say they wire punto 75 injectors onto it and it runs fine.
one way to test the injector is to connect a led to the first coil pack and to the injector wire. if the injector led flashes at half the speed of the coil then the batch fire will be once per engine cycle(720degrees)
might even be able to work out the angle by using the led
oh and about switching between 1 and 2 pulses depending on rpm/load... its not at all needed. once the engine is over a couple of thousand rpm then it wont matter if you used 1 squirt or 10 squirts.
really you want to run the least amount of pulses you can. this is because the amount and quality of the fuel during opening is now reliable.
Did anybody compare data from original 27C512 with modded via hex editor? I did, I haven´t find any differences.. I really would like to upgrade my Lancia Y 1,2 16V for more fuel and limiter moved higher, but with 18F ECU I can´t reach it. Does anybody have here functional 64kbyte BIN file ? I have many files for 75MPI, but for 85 nothing
