Technical how to replace the stering wheel to get to light stalk
sutty2tone
norwich
now im not to sure how to do this,,,but if there any tips ,,on how to take the wheel of,,to replace my light stalk would be great,,,,,,
custard
Status: DEFCON Grumpy
Edinburgh
just a case of unbolt the steering wheel nut and unscrew it to the end of the shaft.DO NOT REMOVE IT!
now depending on your luck it may shift with a good pull,this is why you leave the nut on so you dont get a face of steering wheel.
if that doesnt shift it you can tap the shaft with a hammer while pulling.again leave the nut on and have it flat with the top of the shaft to protect the threads
OP
OP
sutty2tone
sutty2tone
norwich
so with that way will i still be able to put my new light stalk on with out taking the wheel of,,if so im of to do it now,
custard
Edinburgh
sorry no you need to remove the wheel,unless you can stretch the plastic over the wheel ;)
i should have added once the wheel 'pops' off the splines you can then remove the nut and wheel.the nuts there to stop you getting a face full of steering wheel
custard
Edinburgh
oh yeah should have mentioned airbags,in my head i was just looking at the nut.
just to add unless your sure of the job dont go messing with air bags.
