Technical 2000 Brava 1.6 16V revs up to 3000 RPM in neutral
I've got a 2000 Brava 1.6 16v, runs on gasoline & LPG.
For a few years the car has been revving up to 3000 RPMs in neutral whenever I am at a red light. Once I put the car in gear and start moving, revving just stops.
I've taken the car to multiple different mechanics but no luck.
During these years we've tried changing many things, which include spark plugs, spark plug cables, fuses.
Moreover, throttle body was cleaned, and ECU codes were cleared as well.
There are no lights about the engine on the dashboard either.
However still no luck and I am not sure where else to take my car because all the solutions were just temporary so far. It just starts happening after a while.
I'd appreciate your help.
Cheers!
Not sure about LPG kit, but the 1.6 has idle air control valve/actuator that could stick. If you take the intake boot out you should see the throttle body open a bit when you put ignition on.
Or there is air leak in one of the vacuum lines or manifold gasket which is more likely as there is too much air. Smoke machine to one of the vacuum lines to see leaks.
Or the charcoal canister valve is sticking open/leaking?
Alright, I'll check/have checked all these as soon as I can and update here.
Cheers!
Check your Throttle position sensor (TPS) or TDC sensor it might be broken..must be either one or both of them.
Presume you've checked the throttle cable (where present) is nice and free and not binding at all.
You said you had error codes cleared - do you know what they were?
Throttle cable is not the problem. TDC Sensor and Timing Sensor. If both look good, the main problem is your Stepper Motor Sensor. Your vehicle is an automatic transmission right?
