General How do I remove dash to get wire behind it?
Ash85
I installed a GPS antenna on my mirror, the wire goes through the roof lining down the windscreen on the left, but how do I get the wire from the bottom left of the windscreen to my hifi location.
I removed the glove box and the passenger airbag but with no luck at pulling the wires through.
Can anyone help?
teulk
jarrow - tyne and wear
are you sure you really want to remove the dash................wires, wires and more wires. I have a mk1 and there about 8 bolts if my memory serves me right. There are 3 along the top, 2 behind the little speakers in the corners and one behind a cap in the centre. 2 in the glove compartment and another 3 along the bottom of the dash (1 in each footwell and one i think near the centre console). You might find it easier if you remove the steering wheel too. Hope this is of some help. There may be more bolts but i think ive mentioned all of them as it was a while ago when i removed mine - good luck
OP
OP
A
Ash85
That does sound a bit of a bitch to do, so is there ay easier way to getting access to where I need?
Also my Punto is a mk2
pid119
OLDHAM
feed them down one by one at the very edge of the dash there is a tiny gap with a little time on your hands it could go down there maybe ?:confused:
OP
OP
A
Ash85
I've already shoved the wire down the gap, but I cant get my hands in the hifi unit to feed it through
OP
OP
A
Ash85
Just thought I'd post the answer to my own question for anyone who wants to know the answer for future use...
I sent the cable through the right hand side of the windscreen and fed it through the gap, then felt up through the fuse-box for it, then removed the speedo and fed it behind that to the hifi area.
