Technical  Hi and a quick question!
Nominek
Surrey
Just wanted to say hi, im new here! I just bought a 2016 RHD Panda 1.2 for my son. it's so much fun to drive. Can i pick your brains? The Airbag ECU was showing a fault so i had it repaired, but i seem to only have 2 rubber washers with metal top washers in my collection of bits. I assume two of them go into the little cups (on the passenger side), with the metal uppermost, and the drivers side single bolt doesnt have a washer? Have I remembered correctly? Or ive lost it? The third washer that is!
As its to do with motion detection id hate to get it wrong. Anyway looking forward to getting to the forum and thanks for your sage wisdom in advance!
Model
Panda 1.2
Year
2016
So by way of an update, Fiat kindly sent me the attached, which appears to show no washers all so, I wonder what the 2 washers were for? I removed some of the carpet and tunnel trim, so any advice on how the airbag ecu (on top of the tunnel by the bulkhead) should be mounted, or what those washers are for i'd be most grateful!
Hi and welcome:)
Not sure how common a procedure this might be
But you might get better response if you post in the 2012+ Panda section:
