Technical HELP! WTF? Several Error codes and Airbag light and warning
Hi, My two daughters both run Puntos, both cars have had strange/weird warning lights/sounds, no fault codes. After seeking advice from the Punto section, I removed rear light clusters on both cars and really cleaned the terminals, one on each was really badly oxidised, rebuilt them and coated them in copper ease/grease. All problems on both cars gone away, and nothing since............
Cheers Qube O.
Okay!! Get ready for this...
Great guys at Gendan in Swansea set up my Panasonic toughbook with a genuine 3.7 Multiecuscan and OBDLink SX kit and did a full diagnostic as well...
Here are the results log, screen print etc of my Airbat Fault etc... Any ideas after reading the this very lengthy post?
  • MESFAULT.txt
  • FESLog_1707052049_Fiat Qubo 1.3 Multijet.txt
  • FESLog_1707052047_Fiat Qubo 1.3 Multijet.txt
  • FESLog_1707052046_Fiat Qubo 1.3 Multijet.txt
  • FESLog_1707052040_Fiat Qubo 1.3 Multijet.txt
  • FESLog_1707052039_Fiat Qubo 1.3 Multijet.txt
  • Qubods150escanclear.pdf
  • Qubods150escanfault.pdf
:D After advice from Yani at MutiECUscan in email, (BIG THANKS MATE and respect!)
Tonight I checked the wiring from the instrument cluster and managed to clear the fault. It was in the wiring on the fuse line for the cluster giving a low voltage and throwing up the fault. All clear now :) parts used 20cm of wire soldered in place and heat shrink to cover. Clear faults, proxi alinment not needed! All great. No thanks to Fiat dealer who left me high and dry when vehicle is still under warranty! And vehicle disabled adaptation specialist who said the fault was not theirs! Bloke in a wheelchair with a MultiECUscan and laptop and support from Yani got this sorted. Brilliant! Thanks :-D
