I have a 61 plate Qubo my life, and had an issue with the steering wheel buttons. I traced the problem to a broken clock spring. After much googling, I found a replacement clock spring from a supplier in Lithuania. I received the new spring and proceeded to fit it following the instructions from the seller. I disconnected the battery and left it disconnected for 20 minutes, then removed the air bag and steering wheel, replaced the clock spring, re-fitted the steering wheel and air bag, and re-connected the battery. All the buttons on the steering wheel now work, but I now have the airbag warning light on the dashboard, and the odometer is continuously flashing. I have tried, as suggested by a local garage, disconnecting the battery for an hour, then reconnecting it, but the airbag light and flashing odometer are still present.
I have asked a couple of local garages if they can reset the airbag light, but they are unable to.
Is this something that can only be done at Fiat, or does anyone know how it can be done, or someone in the Essex area who can do it?
