This is one for all you computer techies.
I'm trying to sort out an old computer, a Pentium III 600 mhz with 128k ram. Now, I need it to run a 2nd hard disc drive, and previously with other computers I'd just slot it in and connect it to one of the spare IDE cables going to the master hard disc or with one of the CD roms.
However, with this PC I put the second hard disc in, connect it up and the computer doesn't seem to recognise it? I connected it the same way that I connected the same hard disc to computers when I was over in the USA, and it worked over there but doesn't over here
The hard disc is fine as it runs on my old computer (the one I'm using now!). Also, it has the jumpers set to be a 'slave' and the master is set as 'master'.
At the moment the 2nd hard drive is on the same cable as the master disc, though as mentioned above I've also connected it in parallel with CD roms before and it worked fine.
What do I need to do to get the computer to read and recognise the 2nd hard disc? Do I need to change the settings in CMOS or something? Any help would be greatfully received!
Cheers,
Chas
Cheers,
Chas
