Technical  Help identifying part
Jodsclass
Manchester/Cornwall
Evening all.
I wonder if you could help me identify this part. It's a bracket on the end of the cast manifold which is completely missing on my panda. Just had it flagged by a tyre fitter & even though it hasn't been missed, it was put there for a reason, so I'd like to put it back.
It's a circular piece of flat metal which bolts onto a bracket attached to the bell housing.
Any help with identifying the part, so I can get a fresh one & put it back would be great. It's on an 05 Panda 1.2 petrol.
Evening all.
Looks very much like it should be welded to the part of the exhaust pipe it is touching and it has just rusted away.
there should be a complete loop of metal that clamp around the exhaust by the bolt. Most of it looks missing.
Should be an MOT failure. But is often missed
I always look at the beakers. But have never found one. Most of the fiat of this era are the same. Every time I go either they are already been taken off or in a bad state.
its fairly easy to fabricate a new one.
https://www.google.co.uk/search?q=fiat+exhaust+front+mount&ie=&oe=
Thanks everyone.
I'll keep an eye out for a suitable clamp. A standard exhaust clamp in a larger diameter would probably do it, but would pull the end of the engine mounted bracket into the side of the pipe, so I might try some sort of strap clamp and bolt it through using the bolt on the photo, or even use a thin sheet of mild steel and recreate the original clamp with two holes in the end to bolt through. Funnily enough I went through the Haynes manual, and why I couldn't see a similar clamp on the petrol models, I did spot a similar clamp on the diesel model photos it's mounted differently, but I assume the original clamp which has rotted away was this kind of shape (circled in red). Shouldn't be too hard to make something up.
I made a new wrap around clamp but it was too weak to give any useful support. It needs the folded up sides or metal so thick a DIY can't bend it.
I ended up with an ordinary U/C style exhaust clamp with a bracket across it's top bolts.
Looks like the Corsa D has the same clamp. Bet I passed one in the breakers and never even looked. Comes with many part numbers. Wonder how much fiat or Vauxhall charge. It really is a £2 part
124-950, 124950 12855053 46827608 4708719 855868 93193539 Fiat Opel Lancia, 169 199 188 350 178 225 843 955 169 A1.000 169 A5.000, 169 350 199 178 225 188 S07 S10 843 955 188 A8.000 169 A5.000, 169 A1.000 188 A9.000 199 A3.000 199 A2.000 199 B4.000, 188 A9.000 188 A8.000 223 A9.000 199 B4.000 199 B2.000, 199 A2.000 199 A9.000 199 B1.000 199 A3.000 Z 13 DTJ A 13 DTC, 223 A9.000 199 B2.000 199 A9.000 199 B1.000 A 13 DTC Z 13 DTJ, 250252 DURER COEU52 FA1 124950 941950 FIAT 46827608, 350 955 188 178 225, 46827608, 46827608 51816520 GM 12855053 93193539 OPEL 855868 4708719, 855868 4708719, Alfa Romeo 496872 83008710 Ernst HJS CORSA D PUNTO YPSILON PANDA, GENERAL MOTORS 12855053 93193539 KRAFT AUTOMOTIVE 0558526 OPEL, GRANDE PUNTO MITO IDEA FIORINO MUSA STRADA MERIVA B 199 169 843, PEUGE 171390 WALKER 80755, Z 13 DTH Z 13 DTE A 13 DTE A 13 DTR 955 B2.000 330 A1.000 FIAT, Z 13 DTH Z 13 DTE A 13 DTR A 13 DTE 955 B2.000 330 A1.000 BOSAL, Pipe
Manufacturer Part Number 124950
