Heater problem
Heater problem
Catherine94
Good morning I'm Catherine and I'm a newbie to the forum, problem I'm getting on my beloved fiat Bravo 2007 is the heaters, right if I've got them on max the windscreen will clear no problem but as soon as I've closed the max off the screen will start to mist up even if I have got the heaters on hi temperature and full blast..look forward to hearing of you guys...thanks
Ok..
So the flaps are controlled remotely.
Its a common issue requiring VERY awkward access to a relatively simple part.
A member in Hampshire area can perform a fix..
But in the meantime there was a solution posted recently about turning Airflow 'flat.out'..
And that was enough to move the flap.
Sorry ..I cannot post a link.
Charlie
Hi and thanks to all problem sorted my hubby tried leaving the air flow flat out and low and behold it must have released the flap, all good now.
Many thanks again to all Catherine
