Technical Heater playing up
gazza82
So the heater fan has been very intermittent for a few months and as we had this fail in the MiTo earlier in the year decided on a new motor and resistor unit. The MiTo's fan motor was binding (due to rust forming around the bearing!!) and the resistors blew with regularity!
What I found on the Fiat wasn't a pretty site ..
Remember, this is the same wiring system as the Vauxhall Zafira .. or should that be ZaFIREa .. :eek:
New plug on order and then some cutting, soldering and heat-shrink will be necessary!
I have a T-Jet Punto and my heater was gone all of last year and it took me ages to get around to it. Luckily I got away with just buying a used motor from Ebay for about £50 and a new £20 resistor.
Common issue in these along side the Corsa D
