Technical Headlight problem
Kilkennywestman
Hay guys I had a problem with the headlights on my 07 punto the lights were staying on even when the car was turned off. I have changed the two relays and now that's sorted but I have a new problem the lights are now on high beam and I can not get it to go onto pipped beam. Any suggestions
What lights were staying ON initially ? Probably the corresponding relay was stuck closed... Now that you've replaced it switches OFF when you stop the engine but is always ON when power is there. You may have a short in the stalk switch, have a look a the drawing, the relay is T4 for high beam and T3 for dipped, and the switch is H005
BTW: can you confirm that Follow Me Home function was NOT activated ??
BRs, Bernie
If someone here helped You fix -or better, understand- your issue, hit the thanks icon @ bottom right corner, it's free and makes us feel helpy ;-)
Everything turns off when I turn them off but I can't get log beam constantly on high beam
Please be a bit clearer, once you say you can't go dipped beam and after you say you can't get 'log' beam constantly on high beam (whatever that means).
Then someone might be able to help You ...
BRs, Bernie
Sorry I'll try and clarify. I have replaced the two relays that control high beam and low beam but still I'm stuck on high beam. The stalk seems to be OK because when I flash I can see a difference in the light but it still won't come off full lights. At the moment I have disconnected the relay for high beam so I'm not blinding other drivers.
