- Joined
- Jun 16, 2017
- Messages
- 135
- Points
- 36
i tried 2 inexpensive bulbs and an osram night breaker from a friend, ofc the light is better and all but the waird patteren was still there so its not due to bulbs,
Swap bulbs to opposite head lamps. If bad pattern swaps,it's the bulb. If it stays at the same side,it's the head lamp,Then find the fault! Providing the bulbs go easily and properly . If bulbs ok,most likely it's the 'metal hat' that has moved slightly,and only needs correcting with pliers or screw driver to reshape. If it's had a new headlamp,it could be faulty or cheap copy.
As he's got a MK2b it should have H7s for the dipped beam and H1s for the main beam..
I had 2 mk2b puntos, both 2004, one had the little extra metal bits around the bulb in the head light, the other didn’t
See the video I did here to see it didn’t have them.
https://www.youtube.com/watch?v=T3-lmAfqvRc&t=1s
It did make a difference the one with out definitely had much better head lights than the one with. Given that both cars left the factory in the same year, like this. I can only assume it depended one what company made the headlight as to whether or not it had the little metal ring.
It’s not going to kill anyone to see what they are like without and if held in with a screw you can always put them back again
The "cap is part of the overall design of the light. Removing the cap invalidates the type approval of the light.
Robert G8RPI.
I don't know if you have a vehicle safety inspection in Slovenia, but in the UK we have an MOT and if you remove the cap here you would risk failing it for bad beam pattern.
Robert G8RPI.
Robert G8RPI.
yeah i saw your video, thats where i got the idea to remove it,was it any differant light output without the holders?
Pictures of the lights as fitted to my previous cars. No discernible difference in the design of the light except for the ring
The reason they added it was because not all older bulbs had the painted tip
Unless of course you go To Halfrauds for bulbs...their Pad thingy tells you H1 for Dipped H7 for main....At least i knew i needed an H7 for Dipped when i had to get one from them after 1 Blew
i am really torn apart now if i can take it out or not, some of u say okay others that i shauldnt. But the point that like no other car i ever seen has the metal holder means its not that important? or is puntos headlight just that wairdly made?.. problem here is that one of my headlight has a screwed in holder which would be easier to remove and reatach if neccesery, the other has a metal clip holding it, that one will be a pain to remove and imposible to reatach. so yeah.. and yeah my bulbs have the dark tips on them.
