Technical Head gasket blown, balancing options, little money
So is the car driving well at this point in time
The noise is at the front
Does it sound worse from underneath
Is the MAP covered in oil again
So sorry for my delay
I will check very soon
The car goes back and forth — it generally drives well though maybe there’s a lack of power (can tell if it’s me or this is just how the Panda is on certain hills)
It gets into trouble at stop lights and roundabouts — and lately is has a little trouble starting
Idk if the throttle bottle has a leak or somewhere there might be a vacuum leak
Small vacuum leaks aren't a problem, it's seen by and adjusted for by the MAP sensor
As long as it pulls your hand down hard for a couple of seconds it's good enough
If the cars overheated in the past it's not unknown for the plastic inlet manifold to melt slightly
But that does not appear to be the problem here
If it's been burning expensive oil, it likely to have filled up the inlet manifold slightly
Clean the MAP again, push a rag through the hole where it was bolted and soak up as much oil as you can
Temporary disconnect the breather pipe from the cam cover
Take it for a drive and see if there's any improvement
Is there a way to clean the inlet manifold??
Yep take the throttle body off
And push rag towards the drivers side
We just need to see if there's an improvement, a quick and dirty poke through the MAP sensor hole and leave the breather off is good enough for some feedback as to whether we are on the right lines or not
I’ll get on that in the next 15 min!! Thank you!!
Just did that (haven’t removed throttle body for cleaning yet)
Ran very smooth especially at the beginning — could even feel the engine while sitting in driver seat
That noise came back again and I’m not sure what it is
Took videos above and below engine
That great sounds like we are on the right lines here then
Maybe there’s too little oil?
The shop owner advised me not to fill it up all the way — it wasn’t filled to the max dot on the dip stick
They run fine anywhere between mine and max
Since it runs better with the MAP cleaned and breather off, it looking like the problems are around this area
Temporary moving to the noise
The squeaky noise
Is it constantly there
Sounds slower than engine revs
Does it still do it if you flick the auxiliary belt off
The squeaky noise
Let me give that a shot
The squeaky noise
Also, I just cleaned out my breather hose that goes to the cam cover, and I used break cleaner
I’ve done everything I can to let if dry
It is okay that I’ve done that?
I’ve not started it with it connected back on yet
There was actually gunk and yucky build up in there
Fine
The little spigot on the underside of the air box is known to get block
