Basically it will get to the middle line, on a short journey, and especially if at low speeds for a whileFinding hard to use this site at the moment, seem slow
How quick is it heating
How high does the gauge go
Can't see anything diagnostic in the video
It should be halfway in about two miles, and stay there
Unless you turn the heater blowers on then it will drop a bit but soon recover
Let me go do thatPlug 3 looks a little rich
But let not get a head of ourselves
Take the MAP sensor out, one bolt no need to disconnect the electrical cable, look at the top
Is it dry
Is it covered in oil like this
Or is it covered in mayo![]()
Jerkiness on light throttle, esp when cold. | FIAT Panda (Mk3)
I'm experiencing jerkiness on very light throttle when the car (2007 1.2 Dynamic) is cold (also once warm but much reduced). It happens on the transition between being off-throttle and slightly on-throttle, as you gently feed fuel in to maintain speed after backing off to slow down for a low...www.fiatforum.com
Depends if it's got Aircon and if it's onhow often should the cooling fan activate?
Is it dry
Hard to see in the photos
But a drop of oil on the centre of the MAP is enough to cause the fueling to be out
Poor performance, acceleration, idling
