Keepthe12alive
Sorry to bother — is it okay to leave the radiator flush additive and the water in the coolant system until tomorrow?Does the solenoid get blocked again, it's not unusual to have to clean it several times after major head work
I would expect P0011 more than P0016 for a blocked solenoid filter though
If you are 100% the timing. Is correct, and the timing was slightly out originally you can do a phonics relearn
I am trying to avoid this at the moment as the engine has to be warm and able to rev high three times
I should have waited, but I dont want to empty it after it’s just had water in it for it to rust again
