bodie37
Need a bit of advice from some Punto Mk5 owners
I've bought a Mk5 Punto 1.2 Easy privately, for my lad as his first car to learn to drive in. Private purchase and gave the car a good going over but could not drive as not insured. It looked in good nick with no rust and only two car park dinks)
This is our first Fiat.
It has the flashing odometer and battery drain, plus the telephone button on the steering wheel does nothing. After reading various threads, this seems to be the Blue and Me Module, on the weekend I'm going to remove it and send it off for repair, thats £95. Has anybody had this done and is it worth doing? I take it the battery drain will stop if there is no BandM module installed?
I've already replaced the battery, £50
Tonight was the first time we had driven it in the dark. The main bean has a strange problem. Turn it on and the driver's side lights go out. Turn off the main beam, the headlight comes on. Hold the main mean stalk in, as you would if you were flashing someone and the light stays on but not the main beam. I would think that this was the bulb, but if the car is stationary then the main beam works as it should. The dust cover is missing from this headlight and I've had to change the sidelight bulb. Could this be crap on the connections or a loose connection?
Does the Punto Easy have an audible lights-on alarm?
All of a sudden after the battery drain, the radio has no volume, CD's work okay? Is this linked to the BandM module issue?
5th gear is difficult to find, no crunching or anything from the gearbox and reverse seems okay. Anybody else had this
Sorry about all the questions but I need to see if if we keep the car and spend up to a grand on it, (timing belt, new remote key, service items, Blue and Me module, radio problems, auto electrician etc), or a take a grand loss on the car and get rid
Cheers in advance
Cheers in advance
