A sign of the fluid been low tho is when under heavy braking or ""firm"" cornering the light comes on and stays on for 10seconds after
But on saying that - i am fully aware my front disc's / pads are on there way
Ziggy
check pads or brake fluid!!!
My Punto does the same occasionally, the light appears when cornering, braking and accelerating. My fluids all check out and handbrake is not on. So i was told it was my brake fluid sensor, not expensive to fix if this is your problem and it is fine to leave it as long as you regularly check your fluid, pads, disc, handbrake etc
