If anyone who runs the same GSR induction kit on a Punto or Stilo reads this, they will just laugh in your face. And I too would if I were younger.
First of all the induction kit wasw designed in order not to remove the car or re-work the car.
Secondly, you have to pick up the air in the right place. And from your own admission it is quite safe to say that you don't know where the right place is.
And just for your information, the flow of air changes in the CDA three times and not in the best way from the point of flow dynamics.
The filter I use might cost a god 130+ pounds less, but has been proven to flow better than anything else on the market. Me not being pregedist have selected the filter primarily because of its impressing flow characteristics.
When you claim that the air should came as quick and smooth as possible you can't seriously indicate that this is possible with a CDA!
If the GSR wouldn't have a bend it would stick out of the bonnet. Would be great, wouldn't it?
The bends are designed a way to give it under the circumstances the fastest acceptable gas speed with the least restrictions.
The result is the best induction kit ever for this engine, which has proven to give more of a torque improvement than any CDA based induction from any one as well as any other.
No other kit has improved peak power by 10+bhp on this particular engine.
This was a pretty arrogant remark of a proven kit with your unproven attempt.
I have to say that I am more than disappointed that an adult can come up with a statement of such kind.
LOL why does everyone seem to think they can make their own kit better? Do you have any understanding of flow pressures and the optimum requirements for this? Where is your mechanical engineering qualifications?
I say, get to a rolling road day, roll the car with your little home made kit, and then with the GSR, and you'll realise the difference.
The difference here though, is rather than buying some off the shelf "made as cheap as possible" kit which is what most people do, you've ordered a hand made kit with the GSR. You have to understand that when things are made to order the process takes longer. I'm sure you do anyway, as you had a custom kit made elsewhere in the end.
I could go buy a CDA from halfrauds for my pug in much less time than awaiting the GSR kit, but then I pay the same for in affect a loss of power, in which case why did I bother doing the mod?
The kit is imho worth the wait as it is the best one available. Not that Oldschool needs me to talk up the quality of his kit. Theres a reason it sells so well on this forum.![]()
Easy mate, I was not having a go, simply saying what I am allow to say. We can decide on what we all want. I am talking from my personal experience which is subjective.
I have got no problem with personal experience. Neither have I got a problem with competitors products. I also have helped a lot of people make their own induction kit.
Where you have got no personal experience is in what the induction is about you questioned, yet you made a claim.
If my product is not good enough then I have to improve it, which I accept at any given time. But neither I nor potential users appreciate degrading comments that don't even stem from a personal experience.
I'll be honest to say. If that's the GSR kit then I am glad I decided to buy a CDA induction kit instead.
The thing you want most from an induction kit is air in as smooth and quick as possible.
However if you feel the difference then job done. Enjoy it.![]()
Induction kit threads are my favourite.
Smooth and quick and cold (therefore dense) is what you want. The bends in the GSR are smooth and designed to minimise frictional losses. Crucially the bends are there to get the filter nice and low away from the heat of the engine. It is not only the hot air entering the filter that is a problem when your filter is high in the engine bay; it is also the fact that a hot filter will heat the air that passes through it.
If you feel the difference?? Although Funkstar has not had his car RR'd yet, it (the difference made by a GSR kit) is not a matter of opinion. The performance of the GSR kit has been proven on rolling roads time and time again on Barchettas and Punto HGTs. I suggest that after setting up your CDA you should go to the next rolling road day and compare graphs with someone with a GSR kit. Put money on it too if you think you are right.![]()
5. While you might pull some warmer air in traffic jams, the cone sitting more or less directly on the throttle body means you should get exceptional throttle response.
Old School, do you do something for a Mk3 MR2?
But the cone doesn't sit on the throttle body...the last thing you want is warm air being sucked into the engine, this will seriously sap power.
Ideally you need a cold air box.
There is only one thing concerning me about the GSR kit; the filter seems to sit quite low in the engine bay which may/may not make it more vulnerable to ingesting water in the day to day weather we have here in England.
Please tell me I am wrong and give some valid experiences from an everyday driver...
