Technical Gearbox noise
Cirencester
Hi evening, I hope it's been a good weekend. I wonder if anyone has had an issue with a noise from the gearbox, at least I'm pretty sure it is. As the car starts moving there is noise that seems to vary with speed of car, rather than speed of engine so I don't think it's input shaft. If I dip the clutch it makes no difference. Not sure if the drive shaft inner, joint would make this sort of sound. I'm thinking diff bearing perhaps. Gearbox is lovely and smooth to change gears. At high speed the car is fairly quiet.
Any Thought's anyone
Model
Fiat panda 169 2006 4x4 1.2
Year
2006
Mileage
124888
Does yours vehicle have a drive shaft support on the side of the engine with a bearing in it?
Apart from that, wheel bearings as they will increase with speed, although fronts will change the noise as you corner.
Diff bearing noise may change as you accelerate and deaccelerate affecting load on them and the diff gears.
I assume you haven't just fitted some really aggressive treaded tyres as old Land Rovers used to howl.:)
The other way I would check for a noise is properly supported on a wheel free garage ramp and run it up in the gears whilst some one listens underneath.
Sounds more brake related, than driveline, bearing
Does the noise alter if you dab the brakes
Is the noise a scraping, rumbling or something else, a scratching sound immediately the wheels start to turn that speeds up with road speed and goes away when braking is the most common symptoms
Open the passenger window, close it open the drive window, is one side louder than the other
Do you use the car off-road, through deep water
Being a 4x4 does complicates things slightly
There's a bit added to the back of the gearbox and propshaft also in the equation
2006 will have a viscose coupling, which do fail, it's quite a quick test, lift one of the rear wheels and with a long bar, try and turn the wheel, it should spin but be quite stiff, but not locked solid, I don't think it will be this.
We can probably discount the release bearing
Correct we can probably discount the input bearing
A few quick tests, find somewhere empty
Does the noise alter if you jiggle the steering from left to right
Is the noise different if you drive at full lock, lis it different turny left form right
In first, accelerate hard for a second, take you foot off the pedal and let it engine brake, any louder or same as driving normally
It does have the driveshaft support, I will jack up the right side tomorrow and try and look and listen. Don't think it is wheel bearings as it doesn't change on corners. It's on Goodyear 4 season tyres
Are you sure
There a center bearing on the propshaft
But the driveshafts need to be able to move up and down with the suspension
I have tried neutral and clutch down, makes no difference.
Eliminates a fair amount of the gearbox but not all
Do the brakes effect it
Just a thought , will you be able to test it safely with four wheel drive?
I have changed that driveshaft support on other makes of car due to noise.
However was able to safely support on a garage ramp and run the car up in gear whilst underneath so easy to locate the noise.:)
It won't be easy to get all 4 wheels off the ground but to turn the front wheel I can jack up at the front until back wheel comes off the ground I did the left side last week so will try the right I can get to see the drive shaft support bearing at least. Thanks for your help. John
I no idea what we are talking about at the moment
The front driveshafts connect directly to the wheels
Here's the long one on a 4x4
