reset the trip when you next fill. after your usual week remember the litres put back in to fill(make sure the same as last time e.g. 2 clicks then stop) then google a mpg checker you dont need to fill to brim to check you could check after 10 litres or 40 litres the more you do the better average you will get.
You can't check MPG with brimming the tank. Putting only 10L in does not enable you to check MPG at all.
Using 2 click method is also inaccurate as it's not filling to the same point due to so many different variables and different pumps.
OP from what you've said in previous posts assuming your filling at £1.32ppl your mpg is 29.34, but again this isn't very accurate without brim to brim and exact amount filled.
