Technical Front shocks
arseofbox
Principality Retained :)
Midlands
'Lo..Ive finally freed the nut on the top of my NSF shock on the 1242 (it lost an argument against an angle grinder, but mysterously won against the blowtorch..)
Problem I have now is that Ive found the root of the problem - the shock top mount plate had failed (in bearing Id think) and deformed its inner profile from a D-Shape into an O.
Now I need a working top mount and a new nut to get that car back on the road. The nut is easy enough (M12 x 1.25 - find a fastener specialist (y) ), but the top mount isnt.
I have an 899cc Cinq thats gonna be taken off the road in a matter of weeks, so I wanna nick the top mount off that car....but due to equipment issues, I cant have both cars in the air at once. Can I remove the top mount with the car on the ground and the shock on its mountings (just whilst I swap good for knackered - 2mins at most!!)?
rallycinq said:
Nope, it hold the spring in place so you need the strut out and the spring clamped before removing it.
Well, you can do that, but I wouldn't dare with an oil absorber. I did that with a gas one and it worked fine, see the pictures here
https://www.fiatforum.com/showthread.php?t=51505&page=2
Cheers,
Woj
