Tuning parts needed for front coilovers
pandamonium24
Suffolk
Hi All,
I've just picked up a Seicento Sporting and am planning to refresh the suspension soon, I will likely switch to coilovers on the front and to save hassle I want to avoid having to split down the original shock/spring if possible. So can anyone confirm if its only the top mounts that get changed over when going to coilovers or are there any other parts/spacers etc that need to be used? If its purely top mounts then I will buy some new ones for the coilovers.
meshgrid
i used the marked parts + a spacer underneath the top mount (since the top plate of the coilovers was rubbing against the mount in some cases). you can probably get away with just getting new top mounts and then using various spacers to make everything fit correctly
