I tried heating the screws & also using a drift. Still the little buggers would not turn. So I decided to drill them out but then I remembered I had some special tools for removing bolts.
I drilled a 4mm hole all the way through then used the tool to remove them. Sorry cant remember their name, but basically they are a course left hand tapered threaded tap. You turn them anti clockwise and they get really tight then undo the bolt. I thought my tap holder was going to break when all of a sudden the screws came loose!
So everything is stripped down. Regards the main bearings & big end bearings, how do I know what size they are? Mini's always had the size and also if they were over size.
The only details I can see on the Big end bearings are: 7664219 & B in a circle & 7K.
Also anyway of determining the size of the rings?
I need to get a load of parts ordered.
