Technical  Fog lights
Adamek
Praha
Hi everyone, I need some advice. I have a 2019 Fiat Tipo, and the rear fog lights aren't working. I've checked the bulbs, and they seem to be fine. I also couldn't locate the fuses for the fog lights, so I'm not sure what to do next. Any help would be greatly appreciated! Thanks in advance
Model
Fiat tipo
2019
Hello,
you haven't mentionned which body is your Tipo, so I'm uploading the x356 (saloon) doc. I assume only the light clusters shall be different in the estate, but I can be mistaken.
  • x356 Tipo - Rear fog lights.pdf
Hello,
Thanks a lot for the advice, you even got the body type right. I’II get to it tomorrow!
Hello,
Hi, where did you buy the info from please? I can never find the wiring info
Jumping on this thread, but I’ve just found the o/s front foglight smashed on my 2021 TIPO. It’s stormy and cold outside so I’ve not had a chance to check access, but does anyone know how to access the back to swap the unit?
The new Valeo unit has arrived, but apart from a Quick Look at the wheelarch liner which showed the hatch in position for the headlamp but not the foglight the weather hasn’t been good enough to crawl about under the car.
I’ve just done it. Had to take the wheel off to get the arch liner out of the way and then just about reach the two securing screws. Getting it out was a very tight squeeze behind the condenser!
