Technical  Flashing odometer reading
MalcJ
Leyland
After a possible weak battery scenario, my odometer reading started flashing. Also noticed that Blue and Me stopped working, voice commands don't work and a couple of other things. A little research indicated that a proxy reset, whatever that is, would be required.
Phoned a local Fiat dealer who said they could do it while I waited ( a quick little plug in job then) and they would relieve me of £120 plus VAT. I declined.
What are my options to get this sorted ?
Thanks all 👍
Hi :)
The common issue appears to be B+M Unit failure
Replace it..fix it.. or unplug it
The choice is yours :)
Once no Faulty Unit is detected in the vehicles network that Proxy Alignment should stop the flashing
PC based software can do this AlfaOBD
or MES.. Many of us use that for FIATs
Look at the MultiECUScan list on here.. somebody might be near you :)
Charlie
