I think the best person to ask is @
dragonMan
He has a disco in his dash!
Can you throw any light on the matter John
yes, from what i can tell theres some panda's that have back lit dashes, and some that do not.. i think some of the 750's do not have back lit dashes.. however if "some" of the dash lights up, then the whole dash should light up... it would just have a blown bulb.
the bulbs are located (from left to right):
one in the clock (if you have one), one behind the switches, one just behind the red "square" on the hot/cold temp control lever, one on the cigarette lighter and 2 on the top of clocks them selves.
Mr.
CLS, we tried to fit back lit switches to fizzle when you were around here but i did not have any back lit switches at the time (i still dont
).. we did get the clocks lit up though.. if you remember
fizzle sadly does not have the plastic fittings that the bulbs... fit into. you would need to get a new dash surround that had the bulb fittings in.
on the other hand, you could just go mad with LED's like i did with mine.. OK maybe not tri-colour, but it would look good back lit all in red though hmm?:devil:
Mr.
Didge3, if you have back lit switches the rest of the dash should also be back lit unless it has been changed at some point. you just need to replace the bulb behind the red panel on the heating selector.. you have to take the whole front of the dash off though... no need to remove the steering wheel you can get it off with that still on.
just if anyone wants to know.. yellow wire and black wire (taped together) behind the dash are the illumination wires.. some of the lower spec pandas have the wiring, but not the bulbs fitted.. our Bianca was like that.
