Technical Fixing rusted floorboards
smahaley
North Carolina
Piecemeal or buy new pre-made floorboards?
1978 124 CS1- and I’m slowly addressing rust issues. I’ve started on the floorboards and would like some opinions as to my next best step. The video is of the passenger side:
Thanks in advance!
If you havnt yet, take a look at the Eastwood company, they have an awesome selection of the tools and supplys needed for your task at hand...
Can I also recommend something like this rust treatment. You can either brush it or spray it then spread it with a brush. Seems to work really well killing rust (doesnt fill holes tho 😂😂) thx ebay!
Update: so….. we attempted some welding. It was rough going. My buddies helped - which was great - but in the end we wound up cleaning more, cutting holes to good metal, cutting plates of new metal, forming to fit, using JB Weld and self tapping screws and will follow with seam sealer. It was ugly work! But - it will all be more solid than it is, and will be covered up.
If you are struggling with welding you could practice on some of the bits you cut out. Start off setting the wire speed and leave that. Too little wire speed and too much heat/current the wire will melt before it gets to the weld. Too much wire and low heat the wire wont have melted. Just experiment with the settings until you get a steady crackle. Support the torch with your left hand/forearm and with Mig you push the weld along the joint. Watch the weld pool and if it looks like its puddling just release the trigger monentarily. Then resume. There is a lot in technique and it varies person to person.
What you are repairing needs to be structurally sound. Self tappers may be ok before you tack weld but dont rely on them for strength. As for JB weld if you cannot weld the parts it is unlikely JB weld will bond the parts
Practice Practice and you will get there!
Yes, as Twink80 said, don't use JB weld for anything structural...., structural areas need to be welded...practice, flip what you just welded upside down and check for penetration, if you burn thru a critical spot figure out how to fill it back in, your welds dont necessarily need to be pretty but need good penetration, with JB weld I've filled pin holes in autobody , and a cracked marine engine block, as well as drilling and tapping it, and in stripped bolt locations with great success , I was just pointing out the marine version is a great deal tougher that the regular version, I was given a lecture about it by a movie stunt driver who said they use it all the time to fix stuff on the set.
As far as the argon/ Co2 you should be ok, I'm not an expert welder but I've chopped a top, done custom body work, and lots of general patch panels with good success with it, I've never had the opportunity to use anything else but i wouldnt mind trying straight C02...dont give up , practice, if you can find some old body panels close to the thickness of your spider in a friend's back yard, cut pieces and weld them back together, in time you will get it! , a lot of time you will be doing tack welds, practice that a lot, it's pretty easy , tack pieces of scrap every half an inch , this is often how you start with a patch...develop a pattern with the tack welds to get the patch in, and avoid warping, giving the spot time to cool in-between welds, then come back to fill in .
Often you can add plates in areas for additional strength especially if it's a spot that doesn't show..one thing you might consider if you live near a community College, sign up for an evening welding class for one or two quarters, if you make friends with the teacher not only will you learn how to mig weld , but they may let you bring your body in to work on...ask me how I know:)
Just an f.y.i. there's a set of front floor pans I just noticed listed on ebay today, but it's a ridiculous price, however it springs hope someone is making these and if you shop around you might find a pair for a reasonable price..
Please don't repair a classic car with JB Weld.:(:(:(
Cars are built using spot welding etc. If manufacturers thought they could get away with glue they would have done it years ago!!!
Yes I know they are gluing aluminium sports cars these days, but it is done with highly computerised technics.
When I was foreman of a garage and also an MOT tester I would fail that immediately!
You or someone you love may be in that car one day, how would you feel if you had contributed to their death!
I am sorry but I feel very strongly about it.:(
Spend a bit of time learning how to weld properly, it's not that hard, I can do it.;)
Yes sir! Agreed, welding is a fun skill to learn , hate to date myself here, but I remember my first welding experience in the mid 70s in metal shop class in Palmdale CA, after school metal shop class, first thing the teacher did was give us 2 .100 thick plates , and an oxygen acetylene welder, showed us how to light it, and adjust it, and showed us how to make a puddle, then told us we get " no rod" weld the plates together...next came the red Lincoln arc welder everyone had...good times ! But mig works pretty dang good :)
I may have a few years on you.:) My apprenticeship started in 1969 as a 15 year old, the garage had Oxy/Acetylene and a big Arc welder, the Motor Vehicle College I attended was great for most stuff, but the welding instruction was basically as you have just mentioned. It was good how much control was possible as you say, doing it "no rod".
I always liked the Oxy/Acetylene as it was so versatile, Mig is more a case of point and squirt, although less likely to set fire to so much and with a little practice will certainly do the job.;)
Just another crazy idea for you like my community college one, not sure about your locale, but here on the west coast we have company's with mobile welding trucks that come to your location and weld stuff...so if you had say 6 precut pieces ready to fit, and weld, you could call one of them and them come and do the dirty deed...no idea what they cost but I did consider calling them once when I wanted to attach a firebird front subframe to a ford truck frame...they would have done it but I decided to take it to the shop, which might be another option for you if you can find a car fab shop that you could trust with getting the job done in a timely manner rather than parking it in the back of the shop to work on it on slow days..
Thanks for this suggestion!
Thank you - I’ll check the bottle, I think it is a Co2 / argon mix. I’ll do my best to clean the edges of the cutouts - working underneath is not a lot of joy :). And yep - I’m working outside but fortunately under a shed roof and the weather is cooperating….
Years ago I asked BOC a gas supplier for advice and was told CO2 is generally used on new clean steel as its the cheapest gas. Argon mixes make the welding more capable with dirty or pre painted steel. No idea why as Im not a chemist. I have always used Argon mixes since as I rarely weld clean steel. You also benefit from light industrial size gas bottles (apart from cost) at a higher pressure with a pressure regulator as you can better control the supply of shield gas eg if its windy outside crank up the flow
From a personal point of view I found the Argon mix (Cougar) did a hotter weld and on thin metal more likely to burn through, but the pure Carbon Dioxide easier to control. This was on what I call Mot welding/rusty/underseal/old metal etc. At the time early 80s I had a Migatronic 180 amp welder, I have tended to stay with the Co2 with most of my migs apart from when trying stainless steels and aluminium when I used pure Argon. I gave up on aluminium, but used the Argon for stainless steel and still have a bottle for my DC Tig welder, but over all the years I have never reached a standard that I could do easily with Oxy/Acetylene welding.:)
I still have my ox acetylene welding and cutting outfit, been sitting in the corner for like 15 years...still a bit of gas left but not much, I should go fill the bottles and test the hoses because I know there will come a time when I need it, (even though I havnt in 15 yrs:)...I'm curious, bugsymike, I've never tried patch panels in an old car , does it work well? I may give it a try just for the experience :)
It is all we ever used when I started in the trade and you have the advantage of being able to warm the metal to bend to shape as you are working.
Obviously more of a fire risk;)
We had a guy I knew in the late 60s and until he recently passed away used to do all the local trade Mot welding repairs at so economical a price no one bothered to do their own.
He would use a very small flame, do a really neat job and could get so close to a petrol tank without dismantling that he saved hours of labour.
When asked about going over to Mig welding, he answered "Migs are for cowboys!":)
In fairness to him when Migs first came in to regular use we had another bodyshop do some MOT patching when he was busy and when I inspected their work I could tear it off with a screwdriver as they had done no cleaning or penetration of the metal, so they didn't get any more custom from us!
The Oxy/Acetylene was so versatile, as an apprentice late 60s we could use a small nozzle and solder brass radiator header tanks etc. put in a large nozzle and heat a flywheel ring gear to drop on a flywheel, we could change to a cutting torch and burn through thick metal, so most garage jobs. It was also possible with the normal welding torch to cut metal by getting it red hot with the torch and then turning the Acetylene gase off and the Oxygen one up.
We did have a big arc welder also.
Most big fishing boats around here had a set of bottles to cut off trawler gear etc. They called it a "Gas Axe"!;)
The only thing I would say is make sure your regulators have spark arrestors fitted, it is quite frightening when you hear gas popping back towards the bottles!
Also make sure no grease or anything on the gas bottle fittings particularly the Oxygen. I had quite an argument as a young student with a new lecturer who thought he knew everything, only to be proved wrong by me.;) He said it was the Acetylene and I was firm it was the Oxygen.
" Oxygen and other oxidant gases can react violently and produce a fire or an explosion when in contact with oils or grease"
Finally you may find insurance companies very risk averse re most forms of welding equipment and in particular gas.:)
