ferrymanr
I have purchased a Witter FT58A towbar kit (with electrics and ball) to fit to my Punto. All looks a doddle as most fitting points are present in the main structural box section member bthat runs either side of the spare wheel housing - just remove plastic bungs.. However Witter instructions require a hole (about 20mm diameter in 3mm steel) to be drilled into this 'chassis' member to get a strap with captive nut/bolt inside the box sections and locate over existing holes.. I am not keen on drilling holes in chassis members. Has anyone else done this or is there an alternative?
The destructions are at:-
http://www.witter-towbars.co.uk/uMedia/FittingInstructions/FT58A.pdf
Richard
Richard
