My air con pipe broke a few months ago too. Just when the sun came out... Did yours break just below the low tap in point?
Yes it did so Im guessing that I need a new one and aircon needs to be refilled with gas. Can you tell me how much did you pay to change yours??
if its the same one that broke on mine (common one) a couple of weeks ago (pump to condenser) then it is £47 inc vat.
There is a modifcation on the pipe, its slightly longer than the old one (more rubber hose), the new pipe goes inside the rad pipe insted to the side which my old one did.
roy
Where abouts in the engine bay is this part? Will it be on an aircon system on a 1.4 16v![]()
thats a strange one to break, the ones that usually break are the ones on the condenser. mine is right at the front drivers side to the side of the radiator.
i dont know how much that one will be though mate, your best shot would be to call your local dealers and find out - or if you know a good aircon specialist they can sometimes make new pipes - i suspect that one is not gona be repairable as it has the filling point on as well.
it looks in your pic that something has hit that pipe? any ideas
sorry mate
roy
I got a eLearn disc and i've found a diagram of the part:
The pipe is cracked and broken exactly where the red bit is. The eLearn states the part number as 5040A58 but i don't know if thats correct. On ePER, it just looks a mess and its so hard to identify the part. Is this the same pipe that broke on yours Roy, and if so could i have the part number please? Thanks.
It may be cheaper to take the pipe off and have
it repaired by someone like Pirtek.
If the systems got a break like that seal it off
as soon as you realise you have a leak, if not
when it's put right to regas you will probably
need to replace the reciever dryer.
John
