Technical Fiat stilo clutch master cylinder
Matthew01
Serbia
Can someone explain me in details and if possible with pictures how to replace clutch master cylinder on fiat stilo 1.9 jtd. Thanks.
Model
Fiat Stilo 1.9JTD
Year
2003
Mileage
230000
I have done it successfully. If someone needs it, here is the way how I did it. Remove the hose from an oil can. Oil can is the same for braking fluid. From underneath the car unscrew two 13mm nuts with socket extension. Remove the high-pressure pipe from the clutch master cylinder. From inside the cabin, underneath the clutch pedal, there is a joint. Pull the clutch up, and the cylinder will be free. After the new cylinder is installed, you must bleed the system. The nipple is on the hose that goes to transmission. If someone needs further help, feel free to ask.
Matthew
