- Joined
- Aug 2, 2021
- Messages
- 240
- Points
- 129
Would recommend a new 063 battery, still fits if you twist the battery strap and much cheaper than the cube batteries
Sounds like a great tip.
Would recommend a new 063 battery,.
I assume it needs to be a high power battery
Thank you guys for your comments. It is really appreciated. Over weekend the issue got worse. We had one fault code related to the battery so we swapped the battery to a known believed battery (but it wasn't new). We cleaned the terminals when we changed the battery and we will clean the individual positives and negatives to the main terminals of the battery once again. Swapping the battery seems like made a dramatic improvement, however we saw the light again but it turned itself off so possibly it is related to the standing battery. We took it for a drive to charge the battery and we didn't see the light for the rest of the journey. We will continue to monitor it.
We also checked the charging voltage before the journey with the Fluke meter which read 14.2V. We will check this again tomorrow as well. The plan is to remove a steering column cowling and clean the connectors with contact cleaner and reassemble. Is there any reason not to do this e.g. will it lose its calibration?
Also identified the ground behind the battery and it has a Delphi label on it (Part number 00468179840(CAVO MASSA 5NF). We believe it to be a ground cable which bolts into the shock absorber surround. I will try to attach a picture if I can.
We will check the alternator belt tension.
To clarify the battery comments - the battery swapped each year were from a known local scrapyard, not brand new. Thank you for the battery recommendation.![]()
Can I ask what this is please - what effects it causes etc. ?
Hi guys, thanks for your continued support and ideas.
Can anyone point me in the direction of the steering module ground please. As sometimes the light will go on but the steering is fully functional (even in city mode).
Thank you
