Technical Fiat Panda 1.2 2010 Rust issue and possible solutions for it?
kavil
Gibswil
Hello Everyone, i am looking for a Fiat Panda 2010 with 65k km, interior is in really good condition but the underside makes me little worried. There is oily resiedue around the oil pan but it looks semi-old and before and after test drive i did not see
any new fluid on the oil pan or around the car. Exhaust is rusted out a lot and back axis are also rusted, I am not experienced with the rust repair so best i can do clean it and cover it with rust converter and spray or buy new pieces and replace them.
I do not know how bad they are but if possible please look at the photos and give me suggestion about it. Should i proceed forward with the buy and change it by myself or should i avoid it?
Solution
Old is 1145mm length
new 1148mm
Profiles are the same
Amazon and few other car part dealers suggested exact same Gates 5PK1148 for this engine-make and model car. Therefore i bought and installed it instead of the old one (i could not remove the old one before to make comparison so i saw it after the removal). Does 3 mm difference in the length makes a difference? (i know i answer my own question because the belt snapped) but i can not really narrow it down. Original Part number on the belt is 55191970 it says compatible on the package as well Gates 5PK1148 compatible . :mad: I will contact Amazon about the belt as well.
I just come back from test drive. I fitted the old belt back. All the bearings are turning easily...
I would like to try rear view camera ( not that it is needed with this small city car, but rather new toy to play and try to install it.)
In wire loom going to back rear light. Which color cable belongs to rear light? And which place is the best place to tap into it.
For cable routing would it be better to go in ceiling or in floor side?
Lastly which type of fuse is used inside the driver side fuse box with ODB port?
I looked the fuse box under the hood and there are many types of there. I want to buy correct type of fuse tap- piggyback for it.
I like to share info is someone in the future searches for it. So I installed a rear view camera, tapped into the fuse box near the ODB (it's mini type) and used a piggyback fuse holder and extra 5Amp. I dismantled the standard cigarette lighter adapter and crimped earth and + and connected. Now it starts when I turn the ignition on and stops when I turn it off. The wiring was really easy on the ceiling and pillars on the left side. I routed the rear camera to the right side. My car is LHD and the reverse light is on the right cluster. I checked with a multimeter. Rear light cable is on the bottom of the pin only white colour without stripes. I also tapped it so that the camera also goes into reverse mode as soon as I activate reverse gear.
I also changed the auxiliary belt and the timing belt. This time 5pk1145 The timing belt was not easy, it took a lot of elbow grease to get it to fit exactly on the same teeth. (we fitted 2 times with 1 tooth off and had to start again)
I had no timing kit to fix the camshaft and crankshaft so we used old Tippex markings as well as our new markings. So far the car has done around 100km. I hope it does not explode like last time.
I also changed the wipers front and back. They were really noise and new bosch aero ones are so far really good. I hopd it stays quiet like that.
The thermostat should be closed when the engine coolant it cold
It should not allow any coolant at all to pass for the first couple of minuites
The needle does drop if you switch the fans on fast, but should soon stabilise again
At about 5 Celsius a 3 mile drive is half way, with the fans on number 2
After changing the Thermostat i thought all my problems will go away, it was so for couple thousand kilometers. (car is at 93500 at the moment and thermostat changed around 91000. It was working fine and directly solved the coolant temperature not reaching to the half way mark.
But yesterday i noticed something. The coolant needle was around %35-40 percent and not at 50% as it should be after 20 minutes of drive. I also climbed up and down on hills with 3500-4000 rpm to heat the engine and it is rising but as soon as i remove my foot from throttle or drive on higher gear around 2000 rpm it settles around 35-40% coolant temprature. I know faulty thermostat is possible but i confirmed that it is working using boiling water and it really opened around 85-90 degrees and worked for first few thousand kilometers.
Would cold outer temperature prevent motor to reach operating temperature after 25 minutes of driving? I highly doubt it and afraid that new thermostat is already broken but i want to ask you people once again.
As long as there is enough coolant in the radiator
Heaters should blow hit even at idle
It should just be the thermostat
Usual for one to fail so early on
I wonder if part of the rubber washer has got lodged in the new thermostat
Which rubber do you mean exactly? It has enough coolant (exactly at Max level) heater was working fine around 2 fan level. I turned it off but it did not impact the temperature gauge. it only climbed briefly to the 50% when i give gas with high rpm and it fell down to 35-40 pretty quickly. i will try again the pipe holding test. i can also remove the thermostat to inspect it again on the weekend.
really bummer if i have to do everything 2 times... first the aux belt ripped and scared everyone, now the new thermostat might be faulty again.
But hey i was the one to learn and understand cars so i should be grateful for the opportunity. :)
No.
This only confirms that it's opening; it doesn't confirm that it's sealing properly when it's closed. And if it doesn't seal properly when closed, it'll do exactly what yours is doing now.
Every failed Panda thermostat I've seen passes the boiling water test.
I think that's most likely what's happened. Some of the aftermarket thermostats are not of the best quality.
It's cheap and easy to replace it again, so that's what I'd do next.
Thanks for the answers @koalar and @jrkitching . I will look at it whenever i have time. Maybe a dumb question but is it possible to change the inner rubber seal of the thermostat instead of just buying a new unit directly? it seems awfully wasteful to throw something if i can just change the circular rubber sealer. It might does not make a sense on mechanics perspective because the piece is only 10-15€ worth but if possible i would like to try it on the old thermostat first.
If not possible, I changed it with FEBI make and model thermostat, would you suggest another brand this time?
Never swapped the seal or seen one for sale
It's normal the coolant going acidic that causes the washer to fail
If I had a choice, but didn't want to spend for an original
I would use an Original Birth as my preferred second choice
Not a fan of FEBI take a look at there Panda rear bump stops, the don't even fit properly, the locating lug is the wrong shape, they aren't the same quality as they use to be,
I will receive PH tester from a friend of mine tomorrow. Which PH should coolant be? I also confirmed that thermostat is broken. The top pipe is warm without reaching middle therefore it is leaking water internally like the first thermostat that i replaced.
One more question, the handle of the glovebox is somewhat broken, is it possible to dismantle it and change it, i could not see any screws near the handle does it mean it needs to be changed as complete lid?
They are normally slight alkaline
Anywhere between 8 and 9 is normal
No idea
There are at least two different versions, and later cars trim is also a different colour
There should be a part number molded onto the door
Secondhand would be option they don't normally break
If you change the whole glovebox, pop the passenger airbag switch out first, otherwise the rear of the switch will get broken off
I bought a Febi thermostat in November last year for my 1.1, failed last month after about 1500 miles! Put a BGA one in it from my local factors and no issues yet. Maybe a bad batch from Febi? I will add the BGA one has an AWFUL casting and had bits that needed filing off the gasket face!
+1 on the failed FEBI thermostats. Lasted about 3 months. Owner-supllied part.
I usually fit Original Birth or Genuine FIAT ones, not had an in-service failure of one of them yet.
Interesting, not just me then! Original lasted about 13 years so it had a good run, I thought the febi would have lasted at least 5!
My Febi stat only lasted 4 weeks...
I searched but i could not find Birth supplier in Switzerland, Febi is also out of stock so replacement is not possible, amazon offered refund on returned item, There was Gates and Mahle brands but both of them said expected delivery somewhere middle May, fastest one was Calorstat so I ordered it. I will change it next week and if the coolant is acidic that one as well. Even though it looks really new from color and clarity perspektive.
Calorstat is arrived and today i replaced the thermostat for the second time. I tested the old coolant pH and the new one. Both of them around 8 pH.
I replaced it with g12+ ota coolant nevertheless.
FEBI thermostat still had its rubber seal on it but it was leaking. Calorstats build quality is not that great but the first 10km it worked out great. climbed to halfway mark quickly and stayed there during the whole ride. I hope i do not have to deal with thermostat issue once again in next 5-6 years at least.
Steering wheel problem is still present and i am out of ideas about it. Today during thermostat installation i removed the battery tray and once again had opportunity to look at the earth cable. i cleaned original and my additional cables again and bolted them.
I also bought Tyre pressure sensors Jansite for 25€s. i know they kind of useless and short lived but i want to try it nevertheless. Fiat has a lot of gimmicks now, 90w charger, antislip mats, dash and rear view cam, tyre pressure sensors and so on. I might also add new head unit but i am not sure about it yet. All these things are cosmetic and my priority is steering wheel at the moment.
Does it improve
If the battery is left on charge over night?
first and foremost i need to thank you for your continuous help, suggestions and replies. I really appreciate it. Thank you a lot.
Hard to say. I tried with both batteries and it gave steering wheel error after 1 full night of charge. But it happened again early in the morning when it as really cold outside. Afternoon was without an error. Last few days weather is really great and i did not experienced any error.
So your assumption about power related problem is highly likely. (instead of weak earth because everything that i looked look great no corrosion or rust at all. Alternator is outputting 14.2v.
I bought them from Amazon de and on the item page and packaging it says NGK DC7PRE N 10.
I do not know if they are genuine, I trust amazon but I can send them back and buy from another supplier. The problem is that car parts are extremely limited in Switzerland. There are only 2 online suppliers and they cost 3 times as much as in Germany. Therefore I had to use Amazon for almost all equipment - parts.
I use pkwteile.ch. They're based in Berlin and I think the other parts suppliers like Autodoc.ch and Teile-direkt.ch are the same company.
The postage is quite expensive but the parts are cheap, so I bulk order most stuff. Always click the 'Expertenprüfung – holen Sie sich bei der Auswahl von Ersatzteilen fachmännische Bestätigung:'. It costs chf 2 and sometimes they take some time, but can save a lot of future aggravation.
I think you have the same Panda as me (well, my wife), a 2010 1.2. We've had it almost 6 years and done 90,000km in it (now at 210,000 total). We were recently rear ended and got an insurance payout exceeding what we paid for it. Car is still fine to drive. Effectively, we've had a free car.
Grüezi
Sorry to hear that you involved in an accident even though it turns out to be great. I also come across the websites you mentioned which all end with CH but send products from Germany. Do you also need to pay Custom charges if you use such websites? As far as i am informed maximum amount is 275€ or something similar to that. Do you also know any Scrapyard-junkyard which i can buy secondhand pieces? i am looking for a Glovebox lid for months and unable to find it. Its handle is broken and i would like to replace it.
