1) when gear is stuck.. i will switch off the engine ,put the gear back to first gear and then switch on the engine ,then holding clutch drive back home ... since i cannot change the gear will keep in first gear, and drive... during that time i can adjust clutch normally with break/acceleration with first gear engaged back to home .. so clutch is perfectly working right because during first gear i can use clutch effectively ...
2) when gear is stuck , I can engage in reverse gear with engine off then engine on ,then holding the clutch easily reverse as normally ..during engine on i cannot change to any othe gear.. so each time i switch off engine then changes to first gear or reverse gear with engine off ,latter engine on, drive with clutch which accelerate perfectly...
3) after some time ,may be next time gear and clutch work perfectly ... does slave cylinder can work like that if faulty.. as sometimes it wont work but next day it works perfectly...
4) if clutch plate has problem how does next day I am able to drive with all working fine.. ..
5)if clutch plate is problem did able to drive immediately back home in first gear engaged adjusting the clutch/break/accelerator normally.. even i can engage revere gear/engine off, then engine on with clutch normally reverse the car as well.. so mostly on stuck condition i use first gear/reverse gear with engine off, then engine on , with clutch/break/accelerator drive back home.. next day all work perfectly ...
