- Joined
- Aug 5, 2019
- Messages
- 7
- Points
- 3
Hi All
Could really use some help with the below: -
Having issues with my brake carrier holder rubbing on the disc as per the enclosed photos. This has happened after replacing the front wheel bearing.
As you can see the front is tight up against the disc.
Loads of space at the rear though
I asked my local garage to push out the hub/bearing. Could this be because the bearing or the hub have been fitted incorrectly or I have sourced the wrong bearing?
I have never had this issue before and it has got me scratching my head, it's only around 1mm of clearance I need. it's like the hub hasn't been pushed in a far enough maybe?
Thanks for reading.
Darren
Thanks for reading.
Darren
