My car works fine for three to four week then after the battery runs down and there car stops working I charged the battery and then everything happen again I already changed the alternator and still the same problem is this with any one else
Thank you for trying to help me, the blue and me Don’t work
If the car as blue and me then it has Bluetooth
And this is known to cause battery drain if it didn't work
typecastboy is there option in MES to disable Blue And Me so battery stops draining while OP sources another?!
Neto79 where are you based?!
No you'd need to pull the fuse supplying it or disconnect the units itselftypecastboy is there option in MES to disable Blue And Me so battery stops draining while OP sources another?!
Thank youNo you'd need to pull the fuse supplying it or disconnect the units itself
