mookistar
Brilliant guys. So primary methods is align flat blade on outside of thin bar and twist. I need a better screwdriver. Thank you!!
Incidentally guys, assuming I don't find anything, is a clockspring expensive?
£200. ********. Lets hope I find a loose wire although I doubt ill be so lucky.
Absolutley bizarre especially how it chamges source when there's no source button?
How's the steering wheel doing it though?CD button in the middle is Source normally
Magic
Isn't there a button on the steering wheel too swap functions between CD / Radio then
Clock spring shouldn't be stripped down, it's a sealed unit for a reason. Equally you should have got this changed when it originally diagnosed as fault, you're extremely lucky that airbag hasn't gone off in your face and that it's currently only popping fuses and only seems to be the steering audio controls currently affected.
The airbag would throw a warning lamp long before it detontated, I had no fear of that.
