The top holes go all the way through the crankcase---the lower holes are 'blind'. The Abarth reccomended 'mod' was to tap the top holes all the way through (8mm x 1.25mm)and then fit a screw (threaded its complete length) from THE INSIDE, complete with flat washer, spring washer and done up TIGHT. For the bottom holes, use a 'finishing' tap (aka'plug') and gently tap the hole as deep as you can,and the use a stud which uses the complete depth of thread---you may have to modify a longer stud to achieve this. In both cases, the amount of thread protruding out of the crankcase must be long enough so that 2 PLAIN nuts (and a flat washer) can be used. 1 nut to tighten up on the mount and the 2nd nut to 'lock' the 1st nut. Do NOT use 'self-locking' nuts--if a self-locking nut should nip up on the top 'stud' the screw will be wound back into the crankcase. This was a standard 'Abarth' modification. If you wouldlike to e-mail me direct (
[email protected]) I willlet you know all the required dimensions for the screws/studs.
