Technical  Engine stalling
Mypanda12
Kent
Hi all, hope someone can help, I have just registered on this forum to help diagnose what is wrong with my Mums fiat Panda 2009. The issue is that it appears to intermittently stall, but strangely it seems only when the temp needle is below half way, so it runs fine when engine is warm. Starting from cold is no problem but after 4-5 mins of driving is often stalls. The battery is good.
My mum took it to garage and they checked it out, said it was a cambelt issue, so they replaced that (It likely did need replacing anyway as its done over 90K miles), and said its running fine and gave it back, but the issue persists. Then my Brother took it to another garage and asked them to clean out the throttle body, as someone told him that would fix the issue, but the issue still persists. Yesterday I replaced all the spark plugs, and all the HT leads, checked the two coil packs with a multimeter (both reading within spec), but again the issue still persists. The EML is not flashing up, and a quick scan with my cheapish reader reveals no pending codes, although there is x1 stored code (PO115,Engine Coolant Temperature (ECT) Sensor Circuit Malfunction).
Anyone have any ideas ? So far we have
Replaced cambelt (garage used a cambelt kit)
Cleaned soot from inlet manifold
Replaced Spark plugs
Replaced HT spark plug leads
Checked both the coil packs primary & secondary resistances (both readings are within spec)
Thanks for any help, the garages can find nothing wrong !!
Model
Panda
2009
Mileage
90000
Are we talking
Cut out but restarts fine
Cuts out while diving along at speed
Or only stalling at junctions at idle
There quite I few common issues that can be checked without changing parts
The simplest first step.is to remove the MAP sensor and inspect it for oil, it's only one bolt, you can leave the electrical wire connected
Is your car cable or electronic throttle
Also post a picture of the of the old plugs
Thanks for reply Kolar, I should note first that the car is in fact a Mk 2 !! (posted in wrong sub-forum)
So, yes it does restart after stalling. It appears to stall only when coming to a stop or driving slowly; its fine on the motorway at speed !
The throttle is a cable type.
Unlikely to be the crank sensor they fail when hot
It's usually fairly random and usually difficult to restart
Its fairly easy to spot on car with a rev count as it's on zero before the engine fully stops
Start with looking at the MAP
It's on the black intake manifold
Electronic throttle left side, cable throttle right side if facing the engine
1x torch bolt
Not sure about the cable but the electronic throttle you can get to without removing the air box
Thanks Koala, I will post some pics of the removed spark plugs (need to dry them with hairdryer as they been in the bin outside overnight). I will definitely take a look at the MAP sensor ? Will cleaning it suffice, or should I replace ? This stalling issue appears to only persist when the engine has not fully warmed up; for example yesterday my Brother started it and left it running for 1/2 hour, then took it for a drive and it was fine. He then left it for about 5 hours, started it and set off with the engine cold and the issue persists. We think its temperature related somehow, although who knows ???
If it's oil fouled clean is fine
Point it noise down and spray with carb or brake cleaner
Push a strip of cloth through the hole to remove any excess
Depending on whether it's cable or electronic, the electronic ones require a long screwdriver or similar as it sits at the end of a long tube
Thanks will do that tomorrow when its light. The throttle is the cable type, not electronic. Here is some pics of the spark plugs, do these pics reveal anything ?? Thanks again its really helpful
All 4 plugs are rich, it's over fueling
You have a scan tool so we can see if the ltft and stft are in the positive to see if the ECU is adding fuel
But that's latter, after we seen if the MAP improves things
Second from right looks to have a small gap, is that the camera angle
Yep its the camera angle, they all have the same gap, and I agree they all look a bit sooty. The ltft & stft is lost on me but can investigate further if needed, thanks for the info. Anyhow not to dismiss your time and efforts in responding; I have read online that stalling can be caused:
"because the Engine Control Unit (ECU) receives a faulty "cold" signal, causing it to incorrectly adjust the fuel mixture (over-fueling) or trigger a safety shutdown."
and that this could be caused by either a "stuck open thermostat" (unlikely as car is not overheating), "Faulty coolant temperature sensor" (would this not enable the EML light ?), "Corroded wiring or earth strap" (possibly, will take a look at the earth strap tomorrow), "Air locks in the cooling system: That causes the gauge to fluctuate wildly (gauge is not wildly fluctuating). So my reasoning rules out 3 of those 4, leaving only the wiring issue (I really hope its not a wiring issue).
But, I will check the MAP sensor tomorrow as advised and hope it is just that. I will keep the post updated in any case !!
Faulty thermostat on these is fairly common
I never know them to cause stalling
It will over fuel
You should see the car struggling to get half way, should be in the middle within about 3 miles or so along as the cabin fan is only on 1 or 2 setting
It's fairly easy to test the thermostat from cold
But start on the most important
Hi again. I cleaned the MAP sensor this afternoon, unfortunately It has not solved the issue, its still stalling regularly when engine is cold. I did notice that when restarting from a stall it is not instant like I originally suspected, it takes around 5-10 secs or cranking. I'm convinced its a temperature related as the appears to run fine when warmed up, and similarly if the revs are high when its cold. Would anyone consider it could be an issue with the coolant temperature sensor perhaps ?
Unlikely unless it a really wild reading
It runs the temperature gauge as well what's that look like
You've got a scan tool
What the live data from the throttle pedal look like. Is it steady. And smooth when pressing the pedal down
What's the coolant sensor looks like
What the actual rpm look like compared to expected
Whats the long term fuel trims look like
The temperature gauge looks to be operating normally. The coolant sensor I have not yet looked at. RPM sounds normal when it is running. The scan tool I have is just a code reader and even if I did have a proper scan tool with live data readings it would be lost on me. In a nutshell Im trying to diagnose likely culprits and to change them myself rather than take it to another garage for them to not fix the issue and charge me ££££ in the process (which has happened twice now). The car does not overheat ever, and the temp gauge on dash looks normal when it is running. The thing is if I start it, go indoors, have a cup of tea and leave it running for 1/2 hour, it then drives around fine. But if I start it, warm it for a minute and then drive it will stall just up the road.
Without any data to go on
It's would be pure guessing
You might get it right fist time or 10th time
It starts to add up
The only thing we know so far is it's running very rich and it stalls when cold
Like I said earlier there's many possible causes
MAP sensor
Head gasket
Intake to cylinder head leak
Battery, already changed
ECU
Throttle pedal
Throttle body
Faulty wiring
Evap stuck open
O2 sensor
And so on
And a long list isn't very helpful to you
While cold you could try this test
What's the car sound like when cold,.More often than not when the plug are that sorted there's been a misfire causing the fuel trims to go way positive
A cheap £5 elm327 and android phone would tell us if this was the case
Thanks Koala, yes now you put it like that it starts to add up. The car sounds just fine when cold, at least to my ears, no noticeable miss firing, it purrs as it usually did; sounded even finer when the plugs were changed. I will have a look at the linked post and try to digest it. If all else fails will have to get it towed to a bonafide Fiat garage and get them to sort it. BTW what is an EVAP ?
There's a charcoal canister in the back that captures the fuel vapour, there's a valve (solenoid) on the intake that should only let the vapours enter when the engine is hot and the throttle is partially open
It's not unknown for them to stick open, A bead from the canister gets sucked into it and jams
It's easy to check. I have a video on it, let's get the inlet out of the way first
Just take the air box off, at idle if you place you hand over the.throttle body, it should get sucked down really hard, the engine stop immediately and the vacuum maintained for a few seconds
Great will try that tomorrow, the throttle body is under the airbox, its round with the butterfly valve ? Is that correct? If I put my hand over it and engine does not stop it means there's a leak ?
Correct
There a video in the link if me doing the test
Obvious to be of any use it has to be while it's failing
So straight after startup
My gut say it will.not be this, it does cause idle issues, normally there's also some hunting up and down as well,
As it's free to test and quick to test it worth doing
Evap is free to test also but get this out of the way
