M mase Patron member Parked in the garage Joined May 26, 2004 Messages 7,624 Points 1,062 Location where the bloody hell is Oct 14, 2006 #1 .... where exactly is it located on the 1242 engine? with pics showing if possible please... thanking you
SkinzCinqSporting MG ZR Owner :) Written a guide Joined Feb 11, 2006 Messages 6,866 Points 1,040 Oct 14, 2006 #2 Is it not the same position as the 1108, on the block somewhere, says in Haynes.
OP OP M mase Patron member Parked in the garage Joined May 26, 2004 Messages 7,624 Points 1,062 Location where the bloody hell is Oct 14, 2006 #3 SkinzCinqSporting said: Is it not the same position as the 1108, on the block somewhere, says in Haynes. Click to expand... i kinda guessed it was on the engine somewhere lol ive had a quick look through haynes and couldnt find it, but ill have a better peak later
GhostWKD Winning Parked in the garage Joined Aug 31, 2003 Messages 17,252 Points 2,568 Location Banbury, Oxfordshire Oct 14, 2006 #4 where the head meets the block mase, on the left hand side on front of engine, there is a small ledge coming out at teh join (block side) and its printed on there edit: stamped on there Last edited: Oct 14, 2006
Y ycming Patron member Written a guide Joined Oct 13, 2006 Messages 10,264 Points 1,600 Location Glasgow Oct 14, 2006 #5 don't want to make a new thread, but is a simple question. I hve an 0.9 94 cinq, if i was to go for the punto 60 1242 engine, will it be a bolt to bolt swap ?? AM i right that i will also need the ECu fom the punto. Finally dials wise, which should i use? thanks bye for now
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,862 Location Lake District....Moist Oct 14, 2006 #6 ycming said: don't want to make a new thread, but is a simple question. I hve an 0.9 94 cinq, if i was to go for the punto 60 1242 engine, will it be a bolt to bolt swap ?? Click to expand... No, use the search facilty for more info. ycming said: AM i right that i will also need the ECu fom the punto. Click to expand... No, the 1108 ECu will do ycming said: Finally dials wise, which should i use? Click to expand... Cinq sporting, but you need additional wiring, again the search facility is your friend ycming said: thanks bye for now Click to expand... Cheers D
Y ycming Patron member Written a guide Joined Oct 13, 2006 Messages 10,264 Points 1,600 Location Glasgow Oct 14, 2006 #7 for my first question, sorry for been new to this, can you tell me what sort of "word/s" should i search to obtain an correct answer?? Because i am struggling to find the right word/s to search. thanks
SkinzCinqSporting MG ZR Owner :) Written a guide Joined Feb 11, 2006 Messages 6,866 Points 1,040 Oct 15, 2006 #8 just go to the faqs in the tech section
