Blueboy54123
hi guys I'm going to replace the top engine mounts 2011fiat panda 1.2 petrol will I need to support the engine, /gearbox while doing this please
Thanks koalerI put a jack and a plank under the sump when i remove the mount
Simple and works
Yes, that's what I did when changing the cam belt. A good size piece of wood to spread the load.I put a jack and a plank under the sump when i remove the mount
Simple and works
Koaler what's your thoughts on the engine mount can the rubber be replaced and if so what your thoughts on a silicone replacement is the rubber encased or is it a loose pop in replacement TIAThanks koaler
Ok thanks mateLooks like it's got plenty of life yet to me
No you can't just change the insert
On a road car I wouldn't advise fitting something like this either
Just read the other thread, maybe not the dog bone then.Clutch judder from stationary in first or reverse
It's in another thread
