Technical Engine light on - diagnostic showed a misfire
messyhead
I had the engine light come on when driving on the motorway just over a week ago. It also disconnected the stop/start, and I later noticed the cruise control wouldn't work.
So I took it in the garage on Friday, and the diagnostic showed it had a misfire in cylinder 3. But it's been driving fine. The mechanic cleared the codes, and everything worked again.
But today, the light came on again. I suspect it'll be the same fault.
Has anyone else experienced this?
I've only done 16k miles, and it's a 17 plate 1.2 T-jet.
If it showing as cylinder 3 again check the spark plugs and swap the coil pack from cylinder 3 to another cylinder and clear the code if the fault moves to another cylinder you know the coil is faulty
Although if a 17 plate is it still under warranty depending on when it was made?
I'm going to take it into the dealers on Friday and get it checked. If it's the same fault, they can check the electrics. It's got a couple months of Warranty left, so hopefully it can get fixed under that. I'll pay for spark plugs, but anything else is on them.
As long as the fault is found within the time they have to fix it. I had an issue weeks before 3yr warranty ran out. It was fixed a few weeks after warranty had expired.
Was there any messages stating the issue such as emissions etc. Mine had similar Disconnections due to issues with the lambda sensors.
They replaced both the lambda sensors under warranty. The engine management turns off some of the features when there's an issue such as this.
Oh..ok so it was your car I was thinking of..
Cruise is odd.. because it relies on so many inputs : clutch and brake pedal switches..which I would call
Body rather than Engine.. :eek:
Anyway..sounds like its fixed..and relatively cheaply :)
I had misfire on my TIPO 1.4 16v once as well - very cold start, while CEL light already on due to P0420 DTC.
Currently being solved by dealership, they changed the spark plugs - misfire did not show up again but P0420 (cat efficiency) is reoccurring every 50-60 km driven.
Cat is clean from the inside...
They just tried to clean both lambdas instead of replacing them - crucial mistake from my point of view. I'm really getting tired of this :bang:
I finally had it into the garage to have it checked. They said it's the lambda sensor, so they're going to order one and get it back in to replace it. I didn't know there was more than one though, but the report shows they tested one and it had failed.
Be aware, that labdas are better to be replaced in pairs. In my case it ended with ECU replacement. Everyting else was replaced/checked and considered OK, therefore ECU is showing a fault while there is none
Does anyone know if the lambdas are replaced under warranty?
The main dealer is messing me about, and don't return calls, so if it's not a warranty job, I'll just take it to my local reliable garage.
Your warranty is with FIAT
Not that dealer..
If you want better service.. go to a different FIAT approved workshop
There are still some good ones around :)
There isn't many independent near me. Just Arnold Clark or Parks. I'll never use Arnold Clark again, so trying Parks for the first time. I have a garage I take my other car to, but he's a VAG guy.
If they go faulty under warranty yes they should
Only wear and tear items such as tyres and brakes arnt covered
Thanks. I'll pester them some more tomorrow.
I had my Tipo in today for the lamda sensors to get replaced. They changed both, took it on a 14 mile test drive, and declared it fixed.
So I went to collect it, got in the car and turned on the ignition only to see the same warning lights.
Apparently the top sensor is still showing a fault, so they're going to swap them and see if the faults changes. I suspect this all just a crock of sh*te, and the fault is somewhere else.
I'm glad the garage has so far lived up to my expectations.
I have got whole catalytic converter with both lambdas replacet. It wasnt a misfire thou but catalytic converter fail, which is acutally very related to misfires.
