- Joined
- Feb 28, 2016
- Messages
- 770
- Points
- 216
P0654 is likely the error code for wiring issue on the rpm sensor. So check pins on the wiring loom etc. Does the rev counter move when you crank it over
Apologies, yes p0657The code is p0657
Its not even cranking now. Sounds like a machine gun.P0654 is likely the error code for wiring issue on the rpm sensor. So check pins on the wiring loom etc. Does the rev counter move when you crank it over
The battery is flat
Fully chargedThe battery is flat
Brand new. Put in 2 days agoDo you have a volt meter?
How old is battery?- they don't last forever.
Even the action of swinging a new battery in then twisting the cable back to the terminal post can be enough to break the circuitI wonder if this is a another case of rotten earth strap .
The key operates everything as it should. All lights on dash come on and go out as they should, leaving on what it should.Sounds like 30A relay to the ECU
That failing
Fits with both no rev counter and P0657
You can try swapping a couple of identical relays over you might get lucky
However without some basic tools diagnosing problems are very hit and miss
The only information we can get is limited
Does the car centre locking work
Unknown
When you unlock the car does the dash LCD back light come on. Does the remote work
Unknown
When you put the keys in what lights come on
Unknown
After a few seconds of switching the ignition which go off
Unknown
After a few seconds of cranking do any more go off
Unknown
Does the pump prime
Yes
Does the REV counter bounce
No
With the above information
We would know if the body computer is reading the remote
We would know if the key transponder is read by the body computer
We would know the body and ECU were talking to each other
We would know some of the body to dash was working
We would know some of the voltages are present
Which is why some of these questions although seem silly do require answering to help narrowing down the next area of diagnosing
Do you own a multi meter/ or access to one
Do you own a scan tool or access to one
I've tried the jump lead earthing which makes no difference.
It now sounds like a machine gun when i turn the key over, so have the booster on the battery now.
I received the AA final findings and attached to this thread
Booster topping up the battery.Are you waiting now for the booster to top the battery up and then give it annother go or is your booster the connect up to the battery big jump pack.
I want to thank everyone who has helped me along the way. I've changed the battery, put new end on my engine block earth and changed the Crankshaft sensor.
I am up and running again.
Cheers
